Oil Filter Housing Gasket
I think this may be happening to me also. Approximately a half teaspoon of oil every 1-2 days I’m guessing, just from leaving it parked that long and checking the ground, and only started in the past couple of weeks.
Standing on the drivers side of the engine and reaching down, I’ve felt where the OF meets the block, and it’s dry. The drip appears to be coming from about about 6” behind the OF (towards the rear of the car), and inboard of the filter mount a bit. Of course, it could be dripping from anywhere and running back to that point .
No idea if the housing gasket is the problem, but it’s the only thing I can think of.
I keep the underside of the car really clean, so even tho it’s a tiny drip so far, hopefully I can spot it.
It sounds like a PITA to fix; (the things we do for love, LOL!)
