Results 1 to 5 of 5
Thread: Chris build up
    Chris build up
    Well Steve started today, first he removes the OEM fan and cooling reservoir Pwr st reservoir, water pump pulley, lower radiator hose, then removes the stock injectors, installs Cobra 39lb injectors, clocks the super charger to the 6 o;clock position installs the SC then the cross over tube with the two adapters and 90 degree off set for the passenger side coolant sensor. And really that is it, he takes the OEM fan blade out installs it in the new supplied fan shroud relocates the PS reservoir to the drivers vendor well, new coolant reservoir in the passenger corner. Will show that tomorrow, we had to remove the PA speaker for the inner cooler. We are installing a real OP Gage, and a A pillar Aero force gage more pictures to follow tomorrow.
    Jul 2008
    North Georgia
    Man that's awesome! Thanks for the updates and the picts. STOKED!!!
    Tomorrow the inner cooler, reservoir fan and pipes will be on with air box and I will have it on the dyno late tomorrow.
    Jul 2008
    North Georgia
    Looking foward to seeing. Thanks.
    Apr 2008
    stayner ontario canada
    Always like to see this S/C process takeing place every pix tells a story
  1. If they build it, would you buy it?
    By SergntMac in forum Community Discussion
    Last Post: 04-03-2012, 02:26 PM
  2. Happy Birthday Chris
    By james79stang in forum The Lounge
    Last Post: 04-27-2009, 06:21 AM
  3. Build Sheets?
    By Shaft333 in forum Shop Talk
    Last Post: 07-27-2006, 06:08 AM
  4. Idea on how to get Build #
    By 94_302 in forum Community Discussion
    Last Post: 10-14-2005, 12:53 PM
  5. Chris Rock show
    By CRUZTAKER in forum The Lounge
    Last Post: 01-01-2005, 10:41 PM
