Has anyone had this issue with the door panel coming apart or loose like this? What is the best way to repair it? Any advice is appreciated. Thank you in advance.
Take off and use some epoxy and tape or something to hold it in shape while drying. It us fairly common. All my old Vic's started doing it. Depends on use
Clean both surfaces, 5 minute epoxy and painters tape to hold it in place.
This is the normal shape for it !!!! lol J/K almost all the panthers has the same issue
Eaton M112 Supercharger ✓
Intercooler ✓
Lower intake plenum ✓
Coolant Intake Manifold ✓
TB Intake Plenum ✓
Throttle Body ✓
Cobra air intake tube ✓
Accelerator cable bracket ✓
Fuel rails ✓
39lb. injectors ✓
Cobra heat exchanger ✓
lower Metco pulley with hub ✓
Intercooler reservoir ✓
90mm Lightning MAF ✓
MAF to filter adapter plate ✓
Conical air filter ✓
Custom Gortch Brackets ✓
Heat Exchanger brackets ✓
Intercooler pump ✓
Intercooler pump bracket ✓
Ribbed idler pulley ✓
Belt tensioner ✓
Alternator Pulley ✓
Fuel Pump ✓
EGR delete kit ✓
New accessory belt ✓
Cooling tube ✓
IAT sensor ✓
Looking at the part ahead of the arm rest, one of our guys in St Louis has the problem. If you must remove the switch cover for service of the controls, actuator, etc, you are likely to break off the plastic tabs that hold the piece down. I went to the junkyard with two small straight blade screwdrivers and practiced taking off the part. Got a good one on my second try. Pop your piece out and you should see broken tabs on the door side, likely front and rear. $5 at the yard, and $50 in paint, cleaner and softener to do a repaint before re-install. Lots of CV pieces in the yard. Look for '03 & '04 however. I am guessing the control cover must come out to fix the armrest. Good luck.
Last edited by BUCKWHEAT; 03-28-2016 at 03:28 PM. Reason: looked at the wrong part
Thank you very much everyone! Very much appreciated! Will definitely try as everyone advised!
