Page 1 of 3 123 LastLast
Results 1 to 15 of 34
Thread: My Marauder will not upshift from 1st or 2nd gear when at full throtttle; Help
    2003 Marauder will not upshift from 1st or 2nd gear when at full throtttle. It just maintains 5500rpm in 1st or 5000rpm if in 2nd gear. In order to get it to upshift I must reduce throttle position to about 1/2 throttle or a little less.
    I replaced the MAF and have tested with the air cleaner on and off with no difference. I also replaced the coil packs last year, thinking it might help. It did not help.
    The car and engine operate normally except at full throttle. The transmission downshifts normally. Only the full throttle upshift is abnormal. The check engine light is not illuminated.
    I also had the transmission fluid changed just to see if it would fix the problem; it did not. I just checked the trans fluid level and it is a bit high at the top of the hash marked area on the dipstick.
    Has anybody had this problem or have a suggestion as to where to investigate next?
    Thanks
    Jun 2017
    Oxford, PA
    maybe you have a vacuum leak, would explain why it shifts at light throttle ok.
    take it to a transmission shop have them drive it. How many miles are on it?
    The car has 122,000 miles.
    Nov 2009
    Ontario Canada
    Do you have a spare throttle position sensor you can try? Does the up shift issue occur in the 2 - 3 shift at full throttle as well?
    1987 GN running 10's. 2003 MM Blue Sold and dearly missed!
    2003 Black 300B
    Procharger P1sc with air to air intercooler
    3,000 PI converter
    4.10 Eaton posi 31 spline carrier
    Moser 31 spline axles
    Koos headers, with custom stainless exhaust, Megs tips
    Carbon fiber drive shaft
    Metco control arms
    Every autometer procomp gauge in the catalogue
    I will look for any vacuum leaks.
    I will also look at the throttle position sensor. An OEM TPS sensor is only $30, so I will just replace it and hope for a fix. I will report back.
    The up shift issue does also occur on the 2 - 3 shift at full throttle. The engine power/rpm goes flat at 5000rpm and does not upshift to 3rd gear until I reduce throttle to about 1/2.
    Jun 2017
    Oxford, PA
    Any chance your tune is acting up? ---go back to stock tune and see if it shifts OK
    I replaced the MAF sensor and the Throttle position sensor, with no change to the problem.
    It runs totally normal other than the full throttle no shift issue.
    Thanks for the suggestions.
    Drop the pan, inspect the filter. Maybe broken oring on a tv valve.. might be pieces in the pan to help identify what the main issue is
    Does the car just bounce off the rev limiter?
    What rpm does it go up to and your saying it doesn't shift?
    It revs up to 5500 in 1st gear and seems to go flat on power there and will not upshift.
    Feb 2017
    New Orleans, LA
    x2, take out as many variables as you can
    I wonder if I could have an obstruction in the exhaust that is causing the high rpm power loss that does not allow the transmission to reach "shift conditions". Maybe a blocked up CAT?
    Thanks for the suggestion.
    The tune is on a chip, not tuned that way today, it was the way back then. Rheinshart is gone, pissed alot of folks along the way.
    Until this issue, the marauder has been working perfect for 15 years.
    Oct 2003
    Beaufort, SC
    It won't hurt to try this since you've had the PCM out before!!
    Disconnect the negative battery terminal then unplug all electrical connections on the PCM looking for corrosion.....if you find some corrosion clean it up and re-lubricate the connector(s) and hook 'em back up!!
    Reconnect the negative battery terminal and see what happens!!
    Good Luck!!
  1. For Sale full set of marauder seats $285
    By Agent2006 in forum Marauder-specific Parts for Sale
    Last Post: 10-13-2017, 02:43 PM
  2. Replies: 11
    Last Post: 12-03-2014, 10:58 PM
  3. For Sale Full set of OEM wheels plus full spare
    By ctrlraven in forum Marauder-specific Parts for Sale
    Last Post: 09-10-2009, 07:05 PM
  4. Marauder Full Size Spare
    By 2003DOHC in forum Community Discussion
    Last Post: 03-28-2005, 05:25 PM
  5. Crunching sound during upshift
    By MMM2003 in forum Community Discussion
    Last Post: 03-14-2003, 06:56 AM
