Page 1 of 3 123 LastLast
Results 1 to 15 of 39
Thread: SPC Camber kit
    Jul 2010
    Crook County
    SPC Camber kit
    I’m having a nightmare getting the car to carfixer alignment specs after I got the camber spc kit installed. My local Firestone tech is telling me the SPC bolts aren’t adjustable to how they want it. The tech said he wants the passenger side bolt to the left which I highlighted. Also he said he wants the driver side bolt on the right. Somebody please help
    Passenger side
    Drivers side
    300A 8-20-02 #3849
    Webasto Aftermarket Moonroof
    Rear Spoiler
    S55 Tail Light Treatment
    5% Limo Tints
    Fresh Black Paint & PVD Chrome
    Stainless Works Headers & Full Cat Mandrel Exhaust System w/Magnaflow 11229 Mufflers, Martyo Tune & Coolant Mod, Steeda UDP, Stewart WP, JLT CAI & Catch Can, J-Mod, UHaul Pan, Rebuild 4R70W, Dynotech 4' 6061, Forced Lube Mod, 31 Ford Spline Axles, 31 Cobra Carrier w/CF Clutchs, Ford Racing 4.10, TA Girdle & Stud Kit, Carfixer Alignment & SPC Camber Bolts, Ridetech HQ Front Coilovers w/ADTR extended bracket & ADTR Rear HQ Shocks, Arnott P2936 A/C & A-2220 Bags, Gorilla Lock, Cooper Zeon RS3-G1 Tires, Metco Control Arms & Watts Link, Addco F/R Sway Bars, SS Brake Lines, AutoMeter Digital Oil & Volt Gauge, Full VLED Interior/Exterior, Alpine ILX-507, PKG-M780 Headrest Monitors, MRP-F300, R-S65C.2 & R-S68 Speakers, HCE-C1100 & KTX-C10LP Camera System, Viper DS4 & DSM550 GPS SmartStart System, Yellow Optima, BIG III & 200 Amps Alt
    Jan 2017
    Springfield Mo
    Did you. Or he notch out the aluminum frame to get the extra travel?
    Jun 2007
    Whitehall, PA
    I’m thinking whoever installed them did not install them properly, they did not not notch the crossmember.
    2003 DBP/LF - # 36 (Sold)
    2003 DBP/LF - # 205 (Sold)
    2004 Black - Trilogy #43
    2003 Black - shitbox
    Jun 2008
    Waukesha, WI
    I agree they prob didn’t clearance the frame holes.
    Jul 2010
    Crook County
    SPC Camber kit
    The crossmember is notched is what my mechanic who installed them said. I just have a hard time trusting the local Firestone shop.. My Mechanic said he can adjust it to that angle, just gota bring it back to mechanic shop.
    I just don’t know if the Firestone alignment tech actually knows what he’s talking about and if I’m waisting my time getting it adjusted to where he wants it.
    300A 8-20-02 #3849
    Rear Spoiler
    5% Limo Tints
    Nov 2012
    Sacramento
    Print the directions... And have them watch the video. You (or they) will need the notching tool (basically a shaped drill bit/file) that SBC and others sell.
    If you (or they) have never done this... It seems a little different /odd at first, but once you do it it makes perfect sense.
    +4 above it seems they didn't notch the existing hole... And the camber bolt cannot travel/adjust.
    All they have to do to get the big picture is remove the nut. Then they’ll see the notch and try harder..
    Sep 2005
    South Florida
    If the notch is not long enough the cam will not turn 360 degrees, So if they can't get to the needed setting in one direction, then try the other direction. Either that or have the notch enlarged to allow the 360 degree turn.
    TCE
    My Garage
    Jul 2010
    Crook County
    SPC Camber kit
    I believe the Firestone tech didn’t know what he was talking about when he was adjusting the camber because it seems like he didn’t loose the bolt in the back. Then he started bashing the kit saying it was cheap and it wouldn’t turn etc. He mentioned the passenger side camber adjustment isnt where he wants it to be. Also he scratched the hell out my passenger side cam washer.
    So I brought it back to my installer and he got the passenger camber adjustment to where the Firestone tech said he wanted it. Instead of going back to that shady Firestone, I took it to Just Tires and gave them the car fixer specs. Here’s the specs I got after the alignment. When I left the Just Tires shop the alignment was even more off then when I brought it in, with the steering wheel all the way to the right while the wheels are center.
    Called my mechanic and showed him the specs I got and he said bring the car in Friday. So what he plans on doing is drilling more into the passenger low control arm bushing with the SPC 85137. He said he wants to get the “toe” more even. So will have to take it back for another alignment.
    300A 8-20-02 #3849
    Rear Spoiler
    5% Limo Tints
    Nov 2006
    Union City, CA
    My Marauder has a lot of front tire inner wear. Just had some new tires put on and want an alignment. I've asked for carfixer specs before (used to have the specs from MM.net somewhere, can someone please provide them?), but I think I drove away with regular specs. Anyway, last time I was there, they said I needed flaps or whatever its called removed to make further adjustment. What are those things called and please provide me the carfixer specs again. Thanks!
    1988 LTD Crown Victoria S
    Dec 2014
    Hastings, mi
    They call them flags.
    #BSTDMRC #LSSWAPPEDMARAUDER
    Instagram -
    Cheapthrillb2
    lsswappedmarauder
    Sep 2005
    WI
    Courtesy of Carfixer
    The inside edge wear of the front tires is caused by 2 things: negative camber and negative toe (toe out). Caster is not a tire wearing angle. The outside edge wear can be caused by excessive toe in and aggressive cornering.
    Factory camber spec is -.5 degrees or- .75 degrees
    Factory toe spec is -.15 degrees or- .20 degrees
    (BTW, this info came from their website which is updated periodically and may differ from previously published material, such as cd's and paper manuals)
    That means your alignment could have -1.25 degrees of camber and toe out of -.35 degrees and still be in the green. This will wipe out the inside edges in 20K miles IMO.
    All of the MM's I've aligned (about 10) had at least -1.0 degrees of camber and always toe out of -.10 degrees or more from the factory. That's why almost all MM's you see have excessive inside edge tire wear.
    For best tire wear, here is what I use on all MM alignments:
    Camber: 0 to -.3 degrees.*
    Toe: Zero degrees.
    Caster: 5-6.5 degrees positive with .3 degree lead on the right side.
    *Camber can affect cornering feel. The more negative camber you have, the better it will handle corners. Most drivers will never feel the difference, especially on the street.
    Trilogy #167
    Teksid block
    Manley H beam Rods
    Mahle pistons
    Forged crank
    3.0" pulley
    factory exhuast
    Dyno: 436.99 HP 437.81 TQ
    Best et 12.823 (w/ a lot of spin)
    Best mph in 1/4m 115
    Quote Originally Posted by cheapthrillb2 View Post
    They come off with a hammer and chisel. About 30 seconds per side.
    Dec 2014
    Hastings, mi
    I'm well aware. He was asking the name. I provided it. I work in a shop that averages 15-20 alignments a day. I've installed more then my fair share.
    Instagram -
    Cheapthrillb2
    lsswappedmarauder
  1. Camber adjustment mod.
    By Gryphonzus in forum Community Discussion
    Last Post: 01-10-2013, 06:02 PM
  2. SPC camber bolts
    By Comin' in Hot in forum Steering, Suspension & Brakes
    Last Post: 09-24-2011, 04:50 PM
  3. how to adjust camber
    By 4play in forum Tires & Wheels
    Last Post: 01-30-2011, 04:38 PM
  4. Camber Tires
    By SideshowBob in forum Tires & Wheels
    Last Post: 07-07-2010, 04:29 PM
  5. My car lacks a camber kit (?)
    By Black03Marauder in forum Shop Talk
    Last Post: 02-22-2007, 06:28 AM
