Results 1 to 15 of 21
Thread: HVAC - Heat Only
    Feb 2006
    Rosemount, MN
    HVAC - Heat Only
    With the temperature as low as it can go, I only get hot air out the vents, defrost or floor when appropriate button is pushed even with the A/C is on. I hear a clicking sound, so I assume that's the bend door? Is there a Sticky on how to repair this?
    Dec 2009
    Phoenix, Arizona
    You are correct, couple videos on YouTube on
    how to do it without taking apart the dash.
    2004 SB Mercury Marauder
    2003 Mercury Marauder 300B
    Feb 2006
    Rosemount, MN
    I assume the best option (or only option) is to buy a new blend door actuator? Looking on Rock Auto, there are several brands. Some show with manual or Automatic Temperature Control. I believe we have automatic temerature control?
    buy Ford only..aftermarket blend doors are junk
    You do need a blend door actuator. Try running the EATC self-test a few times. It might fix it for a while.
    This is the Ford P/N you need: XW7Z-19E616-BA or YH-1766.
    As stated, only buy that part, aftermarket ones won't last long and you'll be doing the job again.
    Feb 2006
    Rosemount, MN
    I did the EATC Self Test and got an 024 and 025 code. I cleared the codes then ran the test again and just got the 024 code which shows Blend Door Short. So I guess I'll be replacing the blend door actuator. What I don't understand is why it keeps clicking with the HVAC system off.
    Sep 2004
    Roanoke, VA
    Tie a string around your 8mm wrench before you reach WAY up in there to turn those screws.
    04 MM Silver Birch/Light Flint, HS, TO, 6CD, #597 of 3214 (sold 5/2014)
    06 MGM LS Ultimate w/HPP, Black/Dark Charcoal
    04 MGM LS Ultimate
    69 Marquis convertible, 429
    95 F250HD 7.3 4x4
    48 Ford F4
    Feb 2017
    New Orleans, LA
    thats an excellent idea i never would have thought to tie a rescue rope to it lol
    Nov 2012
    Sacramento
    Me too! I smiled a wished I'd thought of it!
    Feb 2006
    Rosemount, MN
    Finally got around to replacing the blend door today. Purchased part# XW7Z-19E616-BA from Amazon for about $50. Took about 4 hours total. What took the longest was trying to remove one of the screws out. What a pain in the butt.
    Feb 2006
    Rosemount, MN
    On my way to work this morning, to test to make sure the new blend door actuator works, I hit the AC button and noticed that hot air was blowing out the vents with the temp set on 70. So, I kept lowering the temp and it finally blew cold air when I got to 60. When I hit the red warm button once, it goes from 60 to 65 and then blows warm air. Before I replaced the blend door actuator, it blew hot air regardless of temperature and would click for a couple minutes. I did verify the blend door moved freely when I removed the old one. I installed a genuine Ford blend door actuator. Any idea what could be causing this?
    Is the top part of the blend door engaged with the actuator?
    Feb 2006
    Rosemount, MN
    Yes. I checked that several times before I closed it back up again. I double checked the part number of the actuator that I removed and it matched the XW7Z-19E616-BA on the new one.
    Feb 2006
    Rosemount, MN
    I'll run the EATC self test to see if I get any codes. I was receiving 024 which is Blend Door Short.
    http://www.idmsvcs.com/2vmod/eatcswap/selftest.html
    Feb 2006
    Rosemount, MN
    This is so frustrating. The temperate adjustment seems to be working now, but the A/C is not working When I turn the A/C or DEF on and set the temp to 60, I can hear the A/C compressor kick in then it kicks out about 2 seconds later. Any thoughts? This morning it was blowing ice cold.
  1. Replies: 12
    Last Post: 10-18-2016, 07:17 AM
  2. New guy with hvac issue?
    By drhill in forum Shop Talk
    Last Post: 12-11-2012, 11:09 AM
  3. HVAC???...what gives
    By biggeorge04 in forum Shop Talk
    Last Post: 09-21-2011, 10:50 AM
  4. HVAC Fan not working!
    By tddpop in forum Shop Talk
    Last Post: 07-01-2008, 02:19 PM
  5. HVAC malfunction
    By Vince Gortner in forum Community Discussion
    Last Post: 03-22-2003, 08:14 AM
