Results 1 to 9 of 9
Thread: Re: Advice Requested / Towing
    Jul 2014
    NY
    So it looks like my right rear axle seal went and now I have oil leaking all over the right rear wheel and brake caliper. I am not a young person anymore and I am having the car towed to the shop tomorrow morning. First time having this car towed. Does it make any difference how it is towed? Flat bed? No flat bed? From the front? From the back? No difference? Thanks in advance.
    Roll back, I wouldn’t use a wheel lift.
    Trilogy # 192 / T.S. 0012
    Apr 2019
    Broward County, FL
    Being the seal is blown out, roll back, or a wheel lift with chalks. Having the rear end spinning will just make a bigger mess and more headaches
    Dec 2018
    Albemarle,NC
    Flat bed is going to be the best. Be prepared to buy axles & axle bearings if the seal is leaking bad. The axle will probably have a groove where the bearing rides pretty common problem on all 8.8 rearends.
    Cochran, Georgia
    Is your Marauder a 2003? If so there is a kit for a complete rear rebuild from Ford. There was a TSB for Fleet cars (but us individuals are not good enough to be included) the kit has both axles bearings and fluid. When I had one of mine done the kit was not much more than a single axle cost. Hope this helps. Good luck. And I agree use a rollback. When mine went bad they used a rollback and when they got it off the right rear wheel just fell off. The axle had snapped.
    2004 SB Marauder, SOLD
    May 2018
    Maryland
    Is this is the kit you are referring to?
    To service, install Rear Axle Bearing Service Kit, Part Number 3W1Z-4A109-AA. Refer to the instruction sheet included with the service kit.
    PART NUMBER PART NAME
    3W1Z-4A109-AA Rear Axle Bearing Service Kit
    Cochran, Georgia
    That part number looks right. Just make sure when you order it you ask and make sure it has both axles, bearings and lubricant. You are better off doing both axles since both of them are bad.
    Just have the shop install relocation bearings. They work just fine.
    Wisconsin
    This^^^^^^^^^^^^^^^^^^^^^^^^^^ ^^^^
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    Legacy 600w 6x9 Rears
    JL 6.5 SubWoofer
    DR Deep Aluminum Trans Pan
    Mo's Dyno Tune
    Gorilla Nuts - The System
  1. Advice Requested
    By Ambitious1 in forum Exhaust
    Last Post: 07-02-2018, 05:33 PM
  2. Advice Requested
    By Ambitious1 in forum The Lounge
    Last Post: 10-22-2016, 08:05 AM
  3. Advice requested
    By 1Marauder in forum Community Discussion
    Last Post: 08-26-2016, 09:13 PM
  4. Advice Requested
    By Ambitious1 in forum Shop Talk
    Last Post: 03-28-2016, 03:48 PM
  5. Towing Advice?
    By gpfarrell in forum The Lounge
    Last Post: 10-19-2006, 10:21 AM
