Results 1 to 11 of 11
Thread: EATC self test info
    Rockford
    EATC self test info
    To self test your EATC(Electronic Auto Temperature Control) : push the Off & Floor buttons together, then push Auto.
    I am told, this is the same for all Fords, with ATC.
    what will this do ?
    Feb 2006
    Tinley Park IL
    ^^^^What he asked^^^^
    Apr 2005
    Frederick County, MD
    Modifications
    Click My Merc for more Pics!
    Rockford
    Unhappy No heat again!
    GMQ is not getting warm.
    This time the codes displayed from the ATC head are 024 & 051
    I replaced the blend door actuator last spring due to the same symptom.
    Electronic Automatic Temperature Control Module Self-Test
    • The EATC module self-test will not detect concerns associated with data link messages like engine coolant temperature or vehicle speed signals. A NGS tester must be used to retrieve these concerns.
    • The EATC module self-test will detect concerns in the system control functions and will display hard diagnostic trouble codes (DTCs) in addition to intermittent diagnostic trouble codes for concerns that occur during system operation. The vehicle interior temperature should be between 4°-32°C (40-90°F) when carrying out the self-test. If the temperatures are not within the specified ranges, false in-car temperature sensor DTCs will be displayed.
    • The self-test can be initiated at any time. Normal operation of the system stops when the self-test is activated.
    • To enter the self-test, press the OFF and FLOOR buttons simultaneously and then press the AUTOMATIC button within two seconds. The display will show a pulse tracer going around the center of the display window. The test may run as long as 30 seconds. Record all DTCs displayed.
    • If any DTCs appear during the self-test, follow the diagnostics procedure given under ACTION for each DTC given.
    • If a condition exists but no DTCs appear during the self-test, refer to the Symptom Chart Condition: The EATC System Is Inoperative, Intermittent or Improper Operation.
    • To exit self-test and retain all intermittent DTCs, push the blue (cooler) button. The control will exit self-test, retain all intermittent diagnostic trouble codes and then turn OFF (display blank).
    • To exit the self-test and clear all DTCs, press the DEFROST button. The vacuum fluorescent display window will show 888 and all function symbols for one second. Then, the EATC control assembly will turn OFF (display blank) and all DTCs will be cleared.
    • Always exit the self-test before powering the system down (system turned OFF).
    • Intermittent DTCs will be deleted after 80 ignition switch ON cycles after the intermittent condition occurs.
    EATC Hard Self-Test Faults
    EATC Intermittent Run-Time Faults
    NGS DTC
    Description
    024
    022
    B1249
    Blend door short
    025
    B1249
    Blend door failure
    031
    N/A
    B1251
    A/C in-car temperature sensor open circuit
    030
    N/A
    B1253
    A/C in-car temperature sensor short to ground
    041
    043
    B1255
    A/C ambient temperature sensor open circuit
    040
    042
    B1257
    A/C ambient temperature sensor short to ground
    050
    052
    B1261
    A/C solar radiation sensor circuit short to ground
    U1041
    SCP invalid or missing data for function read vehicle speed
    U1073
    SCP invalid or missing data for engine coolant
    U1222
    SCP invalid or missing data for interior lamps
    Note: While the above test is useful for diagnosis of suspected eatc related problems, many of the system outputs do not provide any feedback to the control head. Which means there could be numerous problems with your eatc system and you still get a "clean bill of health" from the self diagnostics. For instance, I did not recieve any error codes during the self test when I had the vacuum control block tubes & electrical connector unplugged, the air conditioner compressor request line not connected to anything, and the blend door actuator laying loose on a table without being attached to the plenum. If the eatc system were actually installed inside a vehicle like that, air would always flow from the defroster vents regardless of how the vehicle operator set the controls and temperature regulation would be nonexistent since the blend door could randomly flop around inside the plenum without any restrictions and the a/c compressor would never engage. Additionally, keep in mind that when set to the overide settings of either 60 or 90 degrees, the eatc head ignores temperature and solar radiation data and commands the blend door to either full warm or full cold position. So if you can't get heat in the 90 degree setting and cooled air in the 60 degree setting, your problem is NOT caused by the interior temperature, exterior temperature or sunload sensors.
    Jun 2007
    Woodstock Georgia
    So this will kick a code out if the external temp sensor isn't displaying the correct ambient temp? I have been seeing the issue where my ambient temp is always reading about 10-20° high but as the car warms up so does the temperature displayed. It is an annoyance only as the system seems to operate fine but I would like to know close to what the actual temp is outside. Today at lunch it was reading 107° when it is in the low 90s.
    No I haven't done a search on it yet but came across this thread and though I could maybe pick your brains. Going to try this when I go out for the next smoke break.
    04 SB MM RIP 4/24/09
    03 SB MM (the new girl)
    Mods: K&N CAI, 180° stat, SW headers, custom 2.5" h-pipe exhaust from headers to tips w/Dynomax VT mufflers, Part of the Art Carr Stage 2 tranny kit, rebuilt with Alto Black bands and clutches, deep transmission pan, big ass trans cooler, PI 3.5k rpm Triple disk TC, Dynotech 4" driveshaft, Metco Drive shaft loop and rear CA's, Addco front and rear sway bars, just a bit of powder coating, stock size performance brake upgrades, QA1 shocks in the rear with KYBs in the front, and replaced every stock suspension bushing. Tuner's Inc tuned 298 rwhp/306 rwtq
    Jul 2007
    SOMEWHERE IN MY MARAUDER
    So thats what happens ..............cool
    Norrin Radd
    SURFING WITH THE ALIEN.......SWEET
    If love is blind,why is lingerie so POPULAR ?????
    Only two words really come to mind...."Dang Dude!!" .......as spoken by CBT
    Hey, i just replaced my blend door actuator and am now getting code 051. What does 051 mean? I do not see it on this chart.
    i aint gettin old, my style is wine..
    RIP NICK AKA EMCE
    Quote Originally Posted by bigbillybbs View Post
    THANKS for the Advice,, this forum is the best thing that ever happened to me and my baby!!
    Quote Originally Posted by dankwun View Post
    Google search reveals this:
    http://www.mercurymarauder.net/forum...ad.php?t=82623
    Making this post a sticky.
    I'd run the self teat again. If you get the same error I'd just fugettaboutit.....
  1. EATC self test
    By sounnder in forum Shop Talk
    Last Post: 11-25-2014, 10:35 PM
  2. Wanted To Buy Eatc
    By captain in forum Marauder Wanted
    Last Post: 07-15-2013, 03:13 PM
  3. Wanted To Buy In need of EATC
    By ssmoke14 in forum Marauder Parts/Misc. Wanted
    Last Post: 03-01-2013, 04:30 PM
  4. Test forum example test
    By CRUZTAKER in forum Test Forum
    Last Post: 12-07-2008, 09:48 PM
  5. Eatc
    By Georges93LX in forum Shop Talk
    Last Post: 09-21-2008, 04:36 PM
