I just order a set of SW long tube headers, can any recommend a good exhaust shop to have them installed? I’m located in the Washington, D.C. area.
Thanks
Thanks
You will need a tune as well
Marty will keep you up to date and ready.
I'd contact Maryland Muffler in Millersville
https://www.marylandmuffler.com/
or MBS/Mandrel Bending Solutions in Pasadena.
http://mandrelbendingsolutions.com/
I'd try to reach out to a fellow MM'er to see if someone can help.
You get lead pipes or just LT's?
See if Greg @ Pipe Dreams Fabrication would take on the job, I swear he's done a couple header installs on other cars.
https://www.pipedreamsfab.com/
Greg was THE GUY at MBS who built all the exhausts for any marauder that went to MBS, mine included. He's a good friend of ctrlraven's which is how everyone got in touch with him years ago.
2063/3214
5377/7838
