Results 1 to 9 of 9
Thread: Another carb question
    Apr 2003
    Rock N' Roll Hell
    I am having trouble starting my truck in the morning when it's about 10 outside and it has never been this bad. It will take 3 miniutes to fire up and I keep cranking it over and over. I am new to carbs, but the guy who put it in said it needs more idol. It would always fire up and need to warm up for like a minute but it would always start up without a problem. Now it takes 3 minutes to fire up. What gives? The carb is a week old. What needs to be tweeked? I did add idol, and it actually took longer to start. Any takers?
    "Bye Bye, Johnny B. Goode."
    Aug 2004
    Maryland
    What kind of choke does it have?
    11.98 @ 115 mph
    Apr 2003
    Rock N' Roll Hell
    electric I believe. I know it's an Edelbrock 850.
    Lawrence Twp., NJ
    OK? What make truck? Ford, Chevy etc.....
    Member # 383.
    2003 Marauder Black.
    Build 8/13/02
    Launched 9/28/02
    Sold May 16, 2018
    #3,646 of 7,839 black '03
    Apr 2003
    Rock N' Roll Hell
    Sorry i wasn't posting enough info. 1990 Chevy K5 Blazer. 350 Small block pushing 400 hp.
    Aug 2004
    Fairfield, PA
    Quote Originally Posted by Motorhead350
    Take it to your local speed shop and let them adjust the choke and idle. Watch and learn. It's simple stuff, after the first time.
    May 2004
    Venice, Florida
    Adding more idle speed and adding more cold idle speed are two different things. On the right side of the carb assembly [if it's the one I think it is] is the choke assembly and linkage. With the engine off, open the linkage all the way. On the choke linkage, you'll see a silver screw rotate up from the bottom. This is your fast idle adjustment. You'll need a 1/4 inch open end wrench. Turn the screw in for more fast idle, out for less.
    There should be three phillips head screws on the choke housing. This is your choke "time" adjustment. Loosen the three screws and turn the assembly toward the front of the car one notch to make the choke come off sooner, toward the windshield to make the choke stay on longer.
    I hope this helps...
    2003 Marauder 300A
    Tallboy's Garage
    Apr 2003
    Rock N' Roll Hell
    Great thank you because I just moved the knob back towards the car. I know what you mean about the 3 screws.
    Oct 2002
    Dallas
    I assume that it's hard to start but then runs pretty decent?
    Don't forget you have to "blip" the throttle at least once real good
    to allow the choke to close to the cold position. Normally a couple
    of pumps are required to squirt enought fuel into the engine to get
    it it to fire off. If you do this and then crank it with the throttle closed
    it should pop off, if not then start checking all the basics.
    Ex Marauder owner,
    May 5th, 2003, March Bought new
    February 2007, Installed Trilogy,
    March 30th, 2011, sold to a great home.
    Great car, great people, great times, wonderful memories.
  1. Chip removal question
    By ultravorx in forum Community Discussion
    Last Post: 11-29-2004, 08:49 AM
  2. Sorry Newb question
    By Dark_Knight7096 in forum Community Discussion
    Last Post: 11-12-2004, 10:58 PM
  3. Carb Question (bucking with 4 speed)
    By Thomas C Potter in forum The Classic Lounge
    Last Post: 02-20-2004, 05:53 PM
  4. Autolite 4100 carb ques
    By Thomas C Potter in forum Community Discussion
    Last Post: 09-01-2003, 12:21 AM
  5. Replies: 5
    Last Post: 04-30-2003, 12:26 AM
