Torque nuts & bolts to specs is a good thing for many reasons. My question is for small applicatoins and not haveing a small torque wrench how can one feel 25lbs tq. or guess close ?
You can go to a local auto parts store and pick one up for $20-50 bucks.
2004 Silver Birch 300B
Exhaust by Greg
2015 Ford Focus SE Sport FWD
2010 Ford Fusion Sport FWD
The more I realize the importance the more I see a need. I'll pick one up this week.
...the Craftsman 3/8 drive click style is outstanding for low torque applications:
Sears item #00944594000 Mfr. model #44594
Special Offers:
$64.99 <STRIKE>$74.99</STRIKE>
Save $10.00
thru 04/07/07
<!-- NDSF AddToCartButtons tag --><!-- NDSF Conditional Logic for Price Match Policy -->
<!-- this id was created solely to hid these from printing -->
<!-- End Pricing box --><!-- Start Store Pickup form --><SCRIPT language=javascript1.2>functio n enterSPU(keyStroke,isCol,frm,h asStore){ if (keyStroke == '13'){ if(isCol)_Pd.goSPU(frm,hasStor e); else submitProductSP(frm); return false; } return true;}</SCRIPT><FORM name=storePickupForm action=http://www.sears.com/sr/javasr/findStorePickupProduct.do?BV_U seBVCookie=Yes&vertical=TOOL method=get><INPUT type=hidden value=00944594000 name=pid><SCRIPT language=javascript> if (isValidZipFromCookie()) document.storePickupForm.zip.v alue=cookieZipCode; </SCRIPT> </FORM>
<!-- New code -->
<!-- End Pricing wrapper --><!-- Begin Tabs --><!-- Begin Tabs Navigation -->
<!-- Start Description Tab --><!-- Energystar --><!-- EnergyGuideFlag --><!--Start Display of Short Description-->3/8 in. square drive Wrench measures 10 to 75 ft. lb. in 0.5 ft. lb. increments. Superior internal mechanisms reduce friction and provide accurate and consistent measurements.
Micrometer-type scales stamped into housing show torque settings in both English and metric units. Accurate to 4 percent on clockwise or right-handed reading greater than or equal to 20 percent of capacity. Larger ergonomic handle easily turns to set torque. 90 day limited Warranty.
ΓρεεκΓοδ
For items that use a very low torque reading I use the German Torque wrench GutenTiet; pronounced "Good N Tight". Some might not agree but hey it's worked for me. Each his/her own.
'04 MARAUDERBorn on 4/20/04 -- Foster Care on 5/11/04 -- Adopted on 01/27/05Heated Seats 6 Disc CD Changer MoonroofJLT CAI--Silverstars Heads/Fogs--SCT-9100SB IX - SB X - SB XIII - SB XIV - SB XL - SB XLIIITrilogy S/C In Due Time
What kind of torque wrench do you guys suggest for the Spark Plugs ?
They are supposed to be torqued to 7 - 12 IN LBS.
Pete...
DOB 10/31/2003
DOP 1/2/2004
DOB 12/11/2018
DOP 6/19/2019
The Donk
'03 Black MM
'00 Black Contour SVT
See post #9 in this thread.
ΓρεεκΓοδ
