Page 1 of 3 123 LastLast
Results 1 to 15 of 31
Thread: heated seat problem
    Jul 2011
    Kentucky
    heated seat problem
    my left heated seat stopped working
    is there a fix or known problem for this , the right side works fine and switch works fine
    2003 Marauder 300B 148K 1 of 364 Heated Seats
    2003 Mach 1 5spd Torch red 29K
    Quote Originally Posted by fordnut02 View Post
    Not a common MM problem.
    Do normal PD
    Jul 2011
    Kentucky
    Do normal PD
    Normal PD ?
    Aug 2010
    Winchester MA
    The heating elements will fail with age, miles, heavy driver etc.. My drivers element died about a year after getting the car. Ford still sells the elements or you can get a Dorman kit instead
    2004 Mercury Marauder 300A Black
    Build date: 9/26/03 552 of 3214 2004's
    105K miles Second Owner. Charcoal interior Heated Seats All stock with Lidio 91/93 Octane tune 14.85@95.63 with 93 tune only. 96 cobra intake cams in the cellar, pondering TR6060 swap.
    Pictures
    2004 Crown Vic LX 150K Silver Birch with Light flint leather. Auto dim mirror, EATC and steering wheel radio controls. 21mm marauder rear sway bar and wood steering wheel. MM head unit , MM subwoofer coming (really) 04 P-71 80 mm MAF/ airbox 04 p71 zip tube 04 P-71 PCM swap. Heated mirrors with silver birch endcaps coming!!
    Pictures
    1996 Lincoln Town Car Signature
    Touring Edition 250K 2004 PI 2V swap complete! Sold
    Pictures
    74 Laguna S-3 Project car Original 400 Small block
    Jul 2011
    Kentucky
    Quote Originally Posted by Chevyguy View Post
    Dorman kit a direct fit ?
    Normal PD ?
    Normal Problem Determination.
    Here I'll help you out........................
    See if there is power at the connector under the seat. If there is power then the heating element may be bad. If there is no power then check if there is power to the switch and going to the seat. If there is no power to the switch then check the fuses / relays, if there is no power on the other side of the switch then the switch is suspect.
    Aug 2007
    las vegas
    I used my heated seat for the first time last night, all I can say is, where were these in 1977?
    Jul 2011
    Kentucky
    thanks for ck tomm
    Dec 2010
    Topeka, Ks
    My driver's seat doesn't seem to be putting out any heat either. I had it to a shop today and they pulled the seat.
    The verdict was:"The switch and seat module are working correctly. The seat element checks within specs but is not putting out much heat". Both sides were checked with a heat gun and were about 80 degrees F. When I sit in the passenger seat, heat is much more noticeable. There are elements in both the seat bottom and back, correct? A couple of years ago I did have an upholstery repair on the driver's seat to fix where it tears around the buckle insert.
    Any thoughts? Thanks.
    Apr 2011
    South Florida
    Just to chime in because I am curious about this also, my heated seats went about a year ago. The button still lights up when pressed but no heat present I'm sure the dealership has a hefty price tag for this one. What are our options ?
    Heating elements go bad, if you have low heat, I would suspect the element itself, not turning on is a completely different issue.
    That said, I bought a stack of those elements from a members estate sale a couple years back.
    Trilogy # 192 / T.S. 0012
    May 2006
    Seattle, WA
    Not to derail this thread, but has anyone experienced overheating from their heated seats? Like almost burning your butt hot?
    What would be the culprit here?
    Bean Burritos
    Bean Burritos
    No..... Butt Burrnitos!
    My DS heat doesn't work as well as it did when new. As stated previously the heating elements age with use and become less efficient / effective over time and use. This summer I'm going to try and retrofit aftermarket carbon fiber pads into the front seats and add them to the back seat(s). Looking for a set that has rectangular switches as I don't like the round ones. Will also look at adding a heated pad to the center position of the rear seat with the switch in the back of the center console.
  1. Heated Seat Troubleshooting
    By MM03MOK in forum Interior Electrical/Electronics
    Last Post: 01-26-2014, 09:05 PM
  2. heated seat switch
    By Brian H in forum Shop Talk
    Last Post: 02-16-2011, 06:04 PM
  3. Heated seat inop
    By Matt In Detroit in forum Shop Talk
    Last Post: 11-15-2009, 07:54 AM
  4. Heated Seat Switch lights problem
    By GordonB in forum Shop Talk
    Last Post: 10-01-2009, 01:53 PM
  5. Heated seat installation...
    By 69mach1 in forum Shop Talk
    Last Post: 02-11-2005, 07:39 AM
