So I stopped and bought gas last night. Everything was working fine. Get back in to take off, fire her up, and I have no speedo, tach, or console pod gauges. HELP?!
No gauges or no lights in the gauges?
Speedo/tach not reading, but lit.
Volts/oil pressure not reading, no lights.
But volts/oil pressure haven't lit up since I've owned the car
Ended up being a blown fuse. I feel lucky cause everything I seen with similar issues said the cluster was gonna need replaced
back again, now the fuse keeps blowing to the gauges. Only does it intermittently. May go weeks without blowing one, then blow them several times in a drive. Anyone else ever have this problem??
Check the harness in the engine compartment behind the drivers side cam cover. There is a long bolt that may be shorting out a wire in the harness.
Any work done to the car recently?
I'll check that, thanks. I haven't done any work on it lately, but it has had the engine replaced, so that's a possibility.
On another forum someone mentioned that the vanity lights in the sun visors sometimes short out where the wires come out of the a pillar, I'm gonna look and see if those are working or not.
Possible dime stuck in the 12v lighter inside the console?
It's the same harness
Okay, vanity lights and 12v lighter in console working with the blown fuse.
Used my multi meter at the fuse location (#6) and it's reading a full 14 volts while idling. Is there a resistor somewhere that might have gone bad? Cause all the other fuses in the block are only reading around 1.5v
I would say you have a loose ground, or ground wire is not hooked up
Sorry to have to ask this, but are you reading across the fuse or between one end of the fuse and ground?
I stuck the meter prongs to wear the fuse would go into the block.
