I have a 2008 mercury marquis. The EATC system fan stays on high all the time, even when the unit is turn off. Sometimes air will blow out the dash vents. What is my problem, and how can I fix this.
chet
chet
prolly o rings need changed
http://mercurymarauder.net/forums/sh...ad.php?t=80673
Will o rings fix the problem, I don't understand.
it's a vacuum system and when the o rings dry rot they leak causing issues as these. common problem. read this thread as well. You need silicon o rings metric 007
http://mercurymarauder.net/forums/sh...ad.php?t=36922
The staying on high could be the blower motor resistor, BCM, the coming out the dash vents is likely the o rings, so you prolly have two issues.
here is more on the BCM and staying on high speed.
http://www.crownvic.net/ubbthreads/u...Number=2841446
OP you have two problems.
1 - air coming out of the wrong vents is most likely bad o-rings in the EATC.
2 - fan stays on high could be either the BCM or the EATC control board.
Fix the O-rings first and see if the blower speed goes back to normal before digging into the BCM
O-rings have nothing to do with fan speed.
On our way to MV14 the O-rings in Ms.D's car finally crapped out and the car couldn't figure out where to send air. Vents, dash, floor, combos. In the Auto setting it would blast the fan and constantly redirect the air. I had Russ swap the O-rings out and now it works fine. Never touched the BCM. Just advising the OP to tackle the O-rings first and see what happens.
I thought fail-safe mode only meant it would direct all the air to the defroster, not that it would turn on the fan. I learned something here today...
