Results 1 to 15 of 20
Thread: 8-rib pulley help
    Nov 2007
    San Jose
    8-rib pulley help
    Not all of my 8-rib pulley setup fits. The water pump pulley is too deep. Did they change water pump length between '99 and '04? I've got an '04 engine and water pump with a timing cover and 8-rib kit for a '99 Cobra.
    I think I need a shallower 8-rib water pump pulley, one meant for an '04. Also, I heard somebody on here mention an 8-rib alternator pulley with over-running clutch existed. Sure would like to find that item if possible. It would probably help with belt slap getting on and off the throttle.
    Picture below is of my stock pulley (1" from the rear lip to mounting surface) and the much deeper pulleys from the 8-rib kit. They hit the water pump, aren't far forward enough.
    Once you deviate from stock this stuff gets interesting.
    Lifespeed
    I just ran across the 8 rib list a few weeks ago. Not sure if I can find it again.
    I'm not sure on the years or models with them but yes, there is long and short water pumps.
    Definitely go with the added idler that was previously mentioned.
    Once upon a time I had the lip cut off the OEM water pump pulley. It was just enough, but it all had to be aligned just right.
    Oct 2010
    I milled the lip off of the Vortec supplied water pump pulley it worked fine , and you cannot base the water pump pulley off the oem 6 rib pulley , the 8 rib setup has 2 extra ribs making it sit further outboard , you will see once you actually install your pulleys , just make sure the Innovators West is fully seated everything else will be based off of that alignment wise.
    ITS ALIVE !!!!!!!!
    STAY TUNED!!!!!!!!!!
    Nov 2007
    San Jose
    I wonder if I should put on a longer water pump and use the '99 WP pulley? It might be more mechanically correct in terms of centering the pulley load over the WP bearing.
    Lifespeed
    An 8 rib will work fine with a milled stock water pump pulley
    Oct 2010
    No need to change the water pump unless its bad.
    ITS ALIVE !!!!!!!!
    Nov 2007
    San Jose
    It would seem the 8-rib WP pulley wants to be used with the longer, old water pump. The short water pump I have isn't going to work, unless there is a custom pulley out there for such a Frankenstein combination.
    I think I'll just swap the water pump to make the pulleys line up, seems like that would be following a more factory configuration - if there is such a thing. The accessory drive on this car isn't really Marauder anymore.
    Lifespeed
    Nov 2007
    San Jose
    Any leads on the 8-rib alternator with clutch? That wouldn't be a '99 Cobra part, would it?
    Lifespeed
    I believe the high flow water pumps are short ones. But not all short ones are high flow.
    Nov 2007
    San Jose
    Stewart makes both short and long ones. They aren't too clear if the model year determines the length, I'll have to contact them and find out.
    Lifespeed
    If it's any help to you....
    I measured the distance away from the Engine block with no water pump installed. My dads SB has a 6 rib setup on his vortec V2 and on his electric water pump the belt set 1 15/16 away from the engine block, that's where the belt starts the first rib on the water pump pulley
    The idler pulley directly under the alternator should be less than 3/4 of a inch from the outside most bracket
    This 6 rib idler pulley is 3/4 inch away from the outside bracket
    I assume adding 2 more ribs will push everything away from the alternator,
    On your blower, what is the distance from blower to pulley? This 6 rib is middle finger tip away, I assume yours will be a lot closer because of 2 more ribs
    Hope that helps
    12345678910
    Advhvcgbvvjvvvh
  1. 8 Rib Pulley
    By glassman99 in forum Community Discussion
    Last Post: 06-08-2005, 04:13 AM
  2. Crank Pulley removal help
    By Mard in forum Shop Talk
    Last Post: 04-11-2005, 03:58 AM
  3. Squeaking belt idler pulley
    Last Post: 04-04-2005, 11:09 AM
  4. Help, Searching for 6.8" dia 6 rib steel pulley
    By Thomas C Potter in forum Community Discussion
    Last Post: 03-04-2005, 09:00 PM
  5. Alternator Pulley Removal
    By Joe Walsh in forum Shop Talk
    Last Post: 03-04-2005, 06:38 PM
