Results 1 to 4 of 4
Thread: MAP Sensor on Eaton blower
    Nov 2009
    Newport Beach, CA
    I am doing an Eaton Swap. Do I need to have a MAP sensor? There is one on the Cobra Eaton blower. Is it necessary to wire this into the Marauder ECU? Is that even possible.
    I do not see this on the list of items needed for the swap
    Thanks
    Karl
    No not needed. Just drill and tap a hole in the lower intake to accept an IAT sensor from I believe a lightning. Cut the outer wires on the MAF (greys) and run them to the new IAT location. I use the old MAP sensor hole as a boosted vacuum reference source for the boost gauge and the fuel rail sensor.
    The old MAP sensor has both MAP and IAT together. You can either do as suggested above, or figure out the wiring and tie the IAT portion of the MAP sensor into the MM wiring harness.
    You can use the cobra map/iat sensor but only utilize pins 3&4 for iat
  1. ProCharger Blower coming for MM
    By maraudernkc in forum Power Adders
    Last Post: 02-16-2017, 07:47 AM
  2. Eaton Blower Oil Changes
    By Zack in forum Shop Talk
    Last Post: 09-10-2007, 04:22 AM
  3. Summary of blown engines Cobra motors
    By juno in forum Shop Talk
    Last Post: 11-02-2005, 08:52 PM
  4. Trilogy Blower started going on today...
    By Lidio in forum Alternative Automotive
    Last Post: 02-01-2004, 09:12 PM
