Joe Walsh is going to wet himself over this.
I like how it's for sale in hemmings, but local pickup only.
Years ago someone built an 80s Thunderbird Turbo Coupe with one of those under the hood. Looked bone stock with the hood down. Saw an article or two about it. Incredible. Wonder where that car is today.
First retailed 2003 Marauder
Bought 6 June 2002
#168
