Just bought some saleen wheels rears are 10 inch need to get tires now.
need to know dia. and offset.back spacing. Widened Marauder rims to 9.5 as the shock gets in the way going wider on the Maraudr rim generaly use 295/45/18, some use a 305/45/18 drag radial. rubbing on hock boot can happen
99-04 mustang backpacking. I will need to look exactly what it is.
You may have an offset issue and the rims might stick out past fender opening. 99-04 s95 mustang rims don't fit 03+ panther chassis.Not sure of Saleen wheels, Their offset might be way off the 50mm marauder offset.
Guess if there is an issue they will have to go on the mustang
What type of tire are they using with the 305/45/18? I need some grip since the 3500 stall was installed?
Sent from my SAMSUNG-SM-G935A using Tapatalk
My Hankooks are no good for traction. I need something better, but these still look new
