Results 1 to 10 of 10
Thread: Heated Seat Question
    Nov 2007
    Pleasant Hill, CA
    I know I have seen this before, but for the life of me can not find it while searching through here or Google.
    So the one item on the Marauder that does not work are the heated seats. Fuse is good, lights light up, but zero heat. I have let it go for awhile, but recently started looking at addressing the 'issue'. I came across a Dorman Heated Seat Kit (https://www.amazon.com/Dorman-628-04.../dp/B002U6IL9O). Does anyone know if this would work on the Marauder? It says 'universal' ... but I have learned, not all things are true.
    Anyone have advice, or instructions on how to do it?
    Not sure if I will take it on quite yet, an addition is in progress at home-so time is short, but something for me to look into.
    Thanks!
    Anthony
    Previous
    2003 DPB 232 fo 328.
    Check all the connections under the seat.
    Know that the heating elements will be less efficient over time.
    I'll probably replace mine this year and add them to the rear seats.
    Apr 2010
    South Florida
    Replace with what...? I'm having the same issue. Now the passenger one doesn't light up on the switch.
    Quote Originally Posted by gdsqdcr View Post
    First, be leery of anything by Dorman. Second, for the amount of work it will take to install that kit, you could just as easily fix the seat with the proper parts.
    Pittsburgh, PA
    I think it's a tempting solution. The Dorman stuff seems alarmingly inexpensive, but it's supported by many happy reviews. I understand the common issue with our seats is the wire in the heating elements breaks over time. I'd bet the replacement elements could be slipped under our factory upholstery and wired into the original switches.
    The hot ticket would be to test the wiring and figure out the connections under the seat before tearing into the seats.
    Trilogy #146!!! Self-Installed with a little help!
    Feb 2015
    South Florida
    In regards to the Dorman comment, I installed their window regulator/motor combo on both front doors on my MM and no complaints...
    Righteous Indignation
    03 300A
    4055 of 7838
    4054 of 7093 in Black.
    Born 8/23/02
    Adopted in 1/15
    SOLD
    Lawrence Twp., NJ
    My heated swats are 14 years old and work fine.
    Member # 383.
    2003 Marauder Black.
    Build 8/13/02
    Launched 9/28/02
    Sold May 16, 2018
    #3,646 of 7,839 black '03
    May 2009
    Moreau Island
    Heated seats? Pshaw! Elitists.
    I'm going to replace the fronts with aftermarket carbon fiber elements.
    Will install the same in the rear seats.
    Sep 2008
    B'lo, NY
    I wouldnt mind better seat heaters. Theyre are not as hot as newer cars and dont heat up as quickly. Though on the other hand, I dont drive the car in the winter so do I really car that much? Now, air conditioned/ventilated seats would be cool!
    To do list:
  1. Heated Seat Switch lights problem
    By GordonB in forum Shop Talk
    Last Post: 10-01-2009, 01:53 PM
  2. Heated seat switch light flickers on and off
    By danbike in forum Shop Talk
    Last Post: 11-14-2006, 03:35 PM
  3. Blinking heated seat buttons
    By fastblackmerc in forum Shop Talk
    Last Post: 09-12-2004, 04:16 PM
  4. heated seat backlight blinking
    Last Post: 08-19-2004, 03:28 AM
  5. Car Seat Question....
    By Petrograde in forum The Lounge
    Last Post: 07-11-2004, 10:02 PM
