Are the radio worth fixing in our cars? CD player quit, trunk changer will not eject, radio will not hold stations.
What a good replacement unit?
THanks
THanks
Member # 383.
2003 Marauder Black.
Build 8/13/02
Launched 9/28/02
Sold May 16, 2018
#3,646 of 7,839 black '03
If I remember correctly from what I have read here you can get a audiophile unit from an Escape and it is plug and play. Hope this helps.
2004 SB Marauder, SOLD
This is the quickest way to upgrade..sounds better, steering wheel controls work, have 6 disc in dash instead of trunk so trunk one can be removed as it wont play it anyway.
Have to check with Darren to see if it sold, but here is the model/part number..normally sell for $125-200 on ebay, lkq etc.
https://mercurymarauder.net/forums/s...d.php?t=104798
What they said. I was pretty impressed with the better sound plus it being plug & play.
Ford replaced my factory radio twice. Each time, it lasted about 15 months, and then began its failure chain. First, the AM went. Next, the FM went. Finally, the CD went.
I replaced it with a Pioneer AVIC unit and have loved it for the past seven years.
03 300A
Trilogy #154
Stainless Works LongTube Headers, Magnaflow High Flow Cats, X-Tube, Rear Cat Delete, Borla Mufflers, 2.5 Mandrel Bent pipes
Lido tune
Performance Transmission, 2500 Stall
Yeah, I saw it on the AVIC hack forums, I think.
BTW, has anyone updated their firmware on the 940's with ver 6 (I think that's the latest), from the AVIC Hack site? Pioneer's last release was 4.x I believe. I'm on 4.0 and would like to update the firmware and maps, but don't want to brick it.
03 300A
Trilogy #154
Lido tune
The dash will hold a double-DIN-sized unit, so you might consider an Android Auto unit. They've come quite far in the last year, and integrate nicely with an Android phone. Same is true for Apple and Apple in-Car.
"That's what." - She
Kenny Brown Mercury Marauder 'S' - Kenny Brown Signature Edition #10 of 10
Silver Birch #126 of 4,453
Mercury Division, Ford Motor Company, Panther/Marauders #7,221 of 7,839
MercuryMarauder.Net Member #111 (!)
Exact same sequences as mine; been looking for a replacement option, but have other priorities first. (I can't think of any other manufacturer that considers the radio an item that has to be replaced in the normal maintenance schedule; at least that's Ford's attitude, "Things wear out!" After two years? Really.)
I want to make sure the steering wheel buttons work as well.
BTW I had no problem getting the radio out of my sons Taurus, but this one seems stuck. I used brazing rod last time, but no luck.
Love this forum. Answers to everything here.
I have been shopping for a factory style head unit for a while. The unit pictured in the thread seems to be available under multiple labels on the front fascia. I have seen identical units (same layout / buttons / etc) with the name Mach 300, Pioneer, and the name shown on the picture in the thread above.
They are available all over ebay from around $150 to $250.
Every business that sells these on ebay has a disclaimer that these are 'not compatible' with the stock Marauder head unit.
Anyone know why? Is it that these head units need a separate 'satellite radio' receiver module? I can't think of any other reason.
Thanks -
Keith, rookie member, DTR
Aftermarket radios need an interface module for steering wheel controls to work, it gets wired in and stuffed up in the dash. .Around $50 and a mount kit, $10, and possibly some hand work
