My Adjustable pedals seem to be stuck, when i press the pedal button the pedals barely move, the sound is a short click. Before I take it in to be repaired i just want to know what I'm in for.
the dealer repair is a whole new pedal assembly. a plastic gear breaks and is not serviceable thru ford. as,listed above, member curless has a brass gear custom made to fix this. install instructions on the DIY section
I can't find a listing for the pedal assembly so unless you can find them in a junkyard, and chances will be that they are broken, too, the "Curless Cure" is the best option.
Interesting, I have this same issue and I just thought maybe that is all the movement you can get from the pedals. Good to know that this isn't normal and there is a "cure."
Curless supplies a brass gear to replace the plastic cheapo one Ford uses. You need to PM Curless and see if he has any left. He periodically runs another run of gears if there is demand.
According to the owner's manual (page 58) there is approx 2½ inches of travel.
I contacted Curless and he replied right away, Thanks
