Changed my mind (surprise!). Going to hold on to it.
2011 Infiniti M37x
2000 BMW M5
1976 Jeep DJ5 (postal)
I will be in the DC area in mid Sept. If you still have the car I will PM you to set up a visit.
Sounds like a good car.
I have over 180 races and my car is not abused.
It is driven the way it was designed to.
W/ 86K it does not burn a drop of oil.
OOookay, that is fine, but this is my for sale ad. The cars weren't "meant" to be driven any particular way, and WOT is going to create more wear on bearings, cylinder walls, etc than highway cruising. Higher loads and higher piston speed (rpms) to cover a given number of miles will put more wear on parts over that distance. I'm glad you are enjoying your car and driving it hard, it is certainly a cool car for that, but that was not what I bought mine for, I drive the 2 door stuff hard as weekend warriors. For each his own. Back on topic. Thx.
2011 Infiniti M37x
2000 BMW M5
