Those of you who have done the Eaton swap,did you change the spark plugs???What did you change them to??Thanks.....bugsy
Yes, you'll want to go with a colder plug and a 180* thermostat.
Give Mo's a holler, Jeff can get you hooked up with the correct plugs and thermostat (FWIW, I'd go with a Reisch).
We like the NGKs too.
I do not have the part numbver handy but will get it.
Also, you will need to regao them as well.
NGK 4177 gapped at .032
Mine has the NGK TR6IX.
SEMPER FI From York, Pa
Thanks fellas,exactly what I needed to know.....bugsy
Due to the amount of hwy driving I do my tuner rec I switch to Iridium. They old up longer for steady RPM use.
do you guys think this would be the same for a vortech kit. or would i need something different.
300A Black
On a eaton swap what is the plug gap recomended for Autolite xp Iridium
xp103 ?
I have Autolite's 104 plugs, that I just changed last year, do I still need to change them after the swap?
