Results 1 to 6 of 6
Thread: 13 codes and only have 2nd gear...
    Jul 2018
    Raleigh/NC
    My 2004 ran fine yesterday, but ran rough when I started it today. Check engine light came on immediately at start up and the OD light started flashing. Noted a very faint whine noise at idle and driving. Drove down the road and car started out in 2nd gear and that's where it stays. No slipping. Shifter position does not matter.
    I scanned for codes and found a long list...
    P0403 - EGR
    P2197 - O2 sensor stuck lean bank 2...
    P2195 - O2 sensor stuck lean bank 1...
    P0161 - O2 circuit malfunction bank 2...
    P0155 - O2 heater circuit malfunction bank 1...
    P0141 - O2 heater circuit malfunction bank 1...
    P0135 - O2 heater circuit malfunction bank 2...
    P0446 - Evap vent control circuit voltage
    P0443 - purge control malfunction
    P1747 - transmission electronic control solenoid
    P0755 - shift solenoid B malfunction
    P0750 - shift solenoid A malfunction
    P0743 - torque converter solenoid
    I have a feeling these components are not bad, and did not all fail at once, but wondering if the part of the computer that controls them has a problem.
    Any ideas on what to check? Thanks for any help!!!
    Apr 2010
    South Florida
    Could be a harness issue. Good luck!
    Jan 2013
    Indiana
    I agree... harness issue. double check the black and grey connectors at the back of the engine. Also inspect the body and engine grounds.
    I rebuild AOD/AODE/4R70W/4R75E Transmissions, check out my Facebook page for my latest project; https://www.facebook.com/pages/North...48414635312478
    Jan 2013
    Indiana
    oh... look for blown fuses too. check both underdash and engine compartment fuse block.
    Jul 2018
    Raleigh/NC
    I think I found the problem. When checking fuses, the PCM fuse was very easy to remove and the others fit snug and I needed a tool to pull them. I took a strand a wire and inserted it in each of the two slots before re-installing the fuse. I need to try and move the "tabs" in the fuse box so they make solid contact again.
    Thanks a lot for the suggestions and help!
    Quote Originally Posted by 04CobraSVT View Post
    Glad that fixed it, you’ll need to get that sorted or you will have a “thermal” issue.
    Trilogy # 192 / T.S. 0012
  1. Two Codes
    By tylerdurden2816 in forum Shop Talk
    Last Post: 09-11-2015, 06:35 AM
  2. Codes ?
    By Jeffonebuck in forum Shop Talk
    Last Post: 05-27-2014, 05:58 PM
  3. 024 025 051 ATC codes
    Last Post: 12-23-2009, 09:28 PM
  4. Help with codes
    By Magicape in forum Shop Talk
    Last Post: 04-10-2007, 04:49 AM
  5. Motive Gear Performance 3.90 gear set
    By rayjay in forum Shop Talk
    Last Post: 01-02-2006, 08:56 AM
