Results 1 to 15 of 25
Thread: I got air in my ABS module....
    Apr 2003
    Rock N' Roll Hell
    Exclamation I got air in my ABS module....
    ....because I am an idiot who doesn't deserve to be anywhere near a car. Is there anyway to fix this without taking the car to anyone? Flame suit off.
    "Bye Bye, Johnny B. Goode."
    Quote Originally Posted by Motorhead350 View Post
    How'd you get air in the ABS module?
    Apr 2003
    Rock N' Roll Hell
    I thought it was the air compresser so I took it off. I put it back on, now I have no brakes. I am a frickin idiot. The only thing I did right was not drive it!
    Jun 2007
    Woodstock Georgia
    Have it towed to a shop and power bleed the system. The mechanic will need to open the solenoid in the module with a special scan tool.
    04 SB MM RIP 4/24/09
    03 SB MM (the new girl)
    Mods: K&N CAI, 180° stat, SW headers, custom 2.5" h-pipe exhaust from headers to tips w/Dynomax VT mufflers, Part of the Art Carr Stage 2 tranny kit, rebuilt with Alto Black bands and clutches, deep transmission pan, big ass trans cooler, PI 3.5k rpm Triple disk TC, Dynotech 4" driveshaft, Metco Drive shaft loop and rear CA's, Addco front and rear sway bars, just a bit of powder coating, stock size performance brake upgrades, QA1 shocks in the rear with KYBs in the front, and replaced every stock suspension bushing. Tuner's Inc tuned 298 rwhp/306 rwtq
    Smithfield, Virginia
    Air brakes, WIN!!
    WIN WIN!~ Zack
    Sep 2008
    USA
    What Cougar said.
    Special equipment is required to bleed the ABS module.
    Did you try and bleed the brakes?
    Apr 2007
    Try Windex!
    Excess in Moderation.
    Sprinkles are for winners.
    Apr 2003
    Rock N' Roll Hell
    LOL PAPPA. Bleeding these might solve the problem or will it solve the problem?
    Apr 2005
    Queens NY
    The problem is no fluid going past the ABS module to get to the calipers. Thats why you have to hook it up to the computer to cycle the ABS.
    When I had it done, the laptop selected a wheel then you would hear the ABS buzzing and for 30 seconds, I had to pump the brakes with steady pressure to push it through. After the complete sequence, we did a manual bleed and the brakes were good to go.
    Apr 2003
    Rock N' Roll Hell
    Oh ok I completely understand now. Thanks Paul!
    Apr 2007
    Dec 2007
    Toronto, Ontario, Canada
    Will a "classic" brake bleed never work on these cars then (like a caliper bleed)?
    Are there only certain circumstances that the brakes have to be done through the computer?
    "Barry's" the name;
    Drums and Cars are my game
    "I smash the pedal; air and fuel go in; witchcraft happens; I go fast!"
    "No question is stupid, if you don't know the answer!"
    2004 / Black / 1981 of 3214.
    #184 of 509 in black out of 1214 total in all three colors with the moonroof option.
    Apr 2005
    Queens NY
    Quote Originally Posted by Rockettman View Post
    To get the air out between the master cylinder and the ABS module, You'll need the scan tool, otherwise the old fashioned methed will work.
    Apr 2003
    Rock N' Roll Hell
    Will work?
    I read somewhere about the "poor man's" method to bleed the air bubbles out of the ABS module.....
    Top off the master cylinder.
    Drive down a long, flat unoccupied road and mash the brakes HARD!
    The ABS module will cycle and push the bubbles through towards the brakes.
    Do this several times, while making sure that the master cylinder's fluid level does not go too low.
    Then bleed each wheel's brake cylinder in the normal fashion.
  1. Compass module
    By POWERbyFORD in forum Community Discussion
    Last Post: 02-07-2012, 01:59 PM
  2. GEM module ?
    By Marauder386 in forum Shop Talk
    Last Post: 09-21-2009, 07:33 AM
  3. Abs module
    By Coupe in forum Marauder Parts/Misc. Wanted
    Last Post: 05-11-2009, 01:04 AM
  4. Help! Where is the EC module!!!
    By MarauderBoy in forum Shop Talk
    Last Post: 04-01-2003, 08:23 AM
  5. DRL Module
    By Black Terror in forum Community Discussion
    Last Post: 01-09-2003, 07:56 AM
