Page 1 of 5 12345 LastLast
Results 1 to 15 of 65
Thread: engine block
    Jun 2008
    rockford,il
    engine block
    I have a motor from a 93 mark 8. I have been told its not the same as the Marauder block. Does anyone know.
    Nitrous, a TURBO, 4.10's, are like a hot blonde with a STD, you really want to hit it but you are just afraid of the consequences.
    Best e/t 12.7 @108mph with a 1.9 60' on eagle f1.
    best on e/t streets 12.40 @108 with a 1.6 60'<---- finally NOT faster then justbob.
    Oct 2008
    Ocala, florida
    It's a teksid block, in my opinion the best aluminum mod block. It's not the same as ours.
    Maybe someone knows the difference and can chime in.
    It is a very good block to build far better than a Marauder block the tumble port heads will bolt directly on it.
    Oct 2010
    yeah if its out of a mark8 its a teksid block, you can tell by the sqaure pattern on the top of the block, our (mm) blocks have a diamond shape pattern on top, just google your block #, and you will see you have the best aluminum block you can get your hands on, prolly a 6015
    ITS ALIVE !!!!!!!!
    STAY TUNED!!!!!!!!!!
    Minor differences, but as already stated it will work just fine and it's a great choice for a buildup.
    Jun 2008
    rockford,il
    Ok so the marauer heads will work on it? And what would I need to do to put it in my car. After I built it of course.
    Sep 2008
    LOVES PARK IL
    Quote Originally Posted by LOWBUCKMM View Post
    An engine hoist.
    I have one if you need it.
    Jul 2009
    NH
    You'll need to use your front timing cover on it. I think that has a thick reluctor wheel and two piece crank gears, which will work fine. Check chain guides for wear and make sure the tensioners are good.
    12.073 @ 118.43 (Nitto 555)
    Drag racers prayer:
    Smithfield, Virginia
    Okay Brandon, spill it, are you the next Eaton swap, hmmmmmmmmm????
    WIN WIN!~ Zack
    Oct 2010
    the teksid block is an excellent choice, ill be building my engine with a teksid you wont find a better aluminum block, and some came from the factory with forged cranks.
    ITS ALIVE !!!!!!!!
    Jun 2008
    rockford,il
    Casey I wont lie to you. Its...........
    Jun 2008
    rockford,il
    Quote Originally Posted by motown marauder View Post
    So if it has a 8 bolt crank its forged right??
    Jul 2009
    NH
    That's going to have a 6 bolt cast iron crank. I don't think you really need to worry about the crank though. It's the glass pistons and rods I'd worry about. It's been stated by good builders over and over that the Teksids and the WAPs are just as good. FE if you're going 800+...
    Drag racers prayer:
    Oct 2010
    correct if it has an 8 bolt crank its forged, and the teksid is a far better block than the wap (windsor) block, and yes the rods, and pistons are the weak links in mod motors.
    ITS ALIVE !!!!!!!!
    Jun 2008
    rockford,il
    Well im going to build it for good amounts of boost. So I want it done right.
  1. Need engine block
    By Mike M in forum Shop Talk
    Last Post: 02-01-2011, 10:46 AM
  2. New Use For The An Engine Block
    By MACFORD88 in forum The Lounge
    Last Post: 12-17-2007, 02:59 PM
  3. Warped engine block?
    Last Post: 01-07-2006, 07:58 AM
  4. Engine Block Heater
    By CrazyCor15 in forum Shop Talk
    Last Post: 10-13-2005, 03:45 AM
  5. Engine Block Heater
    By ahess77 in forum Shop Talk
    Last Post: 05-07-2004, 08:19 AM
