Results 1 to 15 of 17
Thread: Need Info?
    PJR Guest
    Need Info?
    I just acquired a DVD with the following information on our cars.
    <table width="0"> <tbody> <tr> <td>
    </td> <td colspan="2">
    TSBs
    </td></tr> <tr> <td>
    </td> <td colspan="2">Field Service Actions (Recalls)</td></tr> <tr> <td>
    </td> <td colspan="2">Workshop Manuals</td></tr> <tr> <td>
    </td> <td colspan="2">And
    </td> <td colspan="2">Wiring Diagrams</td></tr> <tr> <td>
    </td></tr></tbody></table>
    If anybody needs this information for a repair job, etc. let me know.
    You might want to double-check those links
    May 2004
    Normally Ga.
    burnable dvd? might try to talk you out of a copy......
    2003A Mercury Marauder. Sold it, miss it.
    USMC 06-10-96 to 06-21-06. AH-1W and UH-1N!!!! OORAH!!
    Jan 2005
    The Otherside of the tracks
    Quote Originally Posted by PJR
    ...If anybody needs this information for a repair job, etc. let me know.
    Ummmm I'll take a copy please.
    '04 MARAUDER
    Born on 4/20/04 -- Foster Care on 5/11/04 -- Adopted on 01/27/05
    Heated Seats 6 Disc CD Changer Moonroof
    JLT CAI--Silverstars Heads/Fogs--SCT-9100
    SB IX - SB X - SB XIII - SB XIV - SB XL - SB XLIII
    Trilogy S/C In Due Time
    PJR Guest
    Quote Originally Posted by Rider90
    They aren't links. I copy and pasted from the menu of the DVD.
    PJR Guest
    Quote Originally Posted by STLR FN
    I don't know if I have a program that will. In the meantime, I'm sure I can copy and send if anybody has an immediate need for specific information. If so, PM. (some of the files are Acrobat)
    PJR Guest
    Found this information. I don't think anyone has posted this before?
    The vehicle identification number (VIN) is a seventeen-digit combination of letters and numbers. The VIN is stamped on a metal tab riveted to the instrument panel, top upper left of the dash. The VIN number is also found on the vehicle certification (VC) label.
    <table border="1" cellpadding="3" cellspacing="0"> <tbody> <tr> <th align="center" valign="bottom">Item </th> <th align="center" valign="bottom">Description </th></tr> <tr> <td align="center" valign="top">1 </td> <td align="left" valign="top">World manufacturer identifier (WMI) </td></tr> <tr> <td align="center" valign="top">2 </td> <td align="left" valign="top">Restraint type code </td></tr> <tr> <td align="center" valign="top">3 </td> <td align="left" valign="top">Vehicle line and series code </td></tr> <tr> <td align="center" valign="top">4 </td> <td align="left" valign="top">Engine code </td></tr> <tr> <td align="center" valign="top">5 </td> <td align="left" valign="top">VIN check digit </td></tr> <tr> <td align="center" valign="top">6 </td> <td align="left" valign="top">Model year code </td></tr> <tr> <td align="center" valign="top">7 </td> <td align="left" valign="top">Assembly plant code </td></tr> <tr> <td align="center" valign="top">8 </td> <td align="left" valign="top">Production sequence number </td></tr></tbody> </table>
    Vehicle Identification Number (VIN)
    World Manufacturer Identifier (WMI)
    The first three vehicle identification number (VIN) positions are the world manufacturer identifier (WMI) code.
    • 2FA — Ford, Canada, passenger car
    • 2ME — Mercury, Canada, passenger car
    Restraint Type Code
    The fourth VIN position is the vehicle restraint system type code.
    • F — Active safety belts — all positions, driver and front passenger air bags
    • H — Active safety belts — all positions, driver and front passenger air bags and driver and front passenger side impact air bags
    Vehicle Line and Series Code
    Positions 5 through 7 indicate vehicle line, series and body type.
    • P70 — Crown Victoria (Long wheel base)
    • P71 — Crown Victoria (Base four-door)
    • P72 — Crown Victoria (Base four-door)
    • P73 — Crown Victoria (Base four-door)
    • P74 — Crown Victoria (LX four-door)
    • M74 — Grand Marquis (GS four-door)
    • M75 — Grand Marquis (LS four-door)
    Engine Code
    The eighth VIN position is the engine displacement and number of cylinders code.
    • W — 4.6L EFI (SOHC), eight cylinder, gasoline
    • V — 4.6L EFI (DOHC), eight cylinder, gasoline
    • 9 — 4.6L EFI, eight cylinder, natural gas vehicle (NGV)
    Check Digit Code
    The ninth VIN position is the check digit code (0-9).
    Model Year Code
    The tenth VIN position is the model year code.
    • 3 — 2003
    Assembly Plant Code
    The eleventh VIN position is the assembly plant code.
    • X — St. Thomas, Talbotville, Ontario (Canada)
    • S — Pilot Plant, Allen Park, Michigan (USA)
    Production Sequence Code
    The last six VIN positions are the production sequence number. These six digits also are used as the vehicle serial and warranty number.
    • Ford — starts at 100000
    • Lincoln/Mercury — starts at 600000
    Aug 2004
    Fairfield, PA
    The links won't work for me either, is it possible to get copies made, or give an address where we can obtain them?
    Assembly Plant Code
    Anyone have an S in their VIN? Now THAT would be way cool!
    Connecticut
    <TABLE width=0><TBODY><TR><TD>
    </TD><TD colSpan=2>
    TSBs
    </TD></TR><TR><TD>
    </TD><TD colSpan=2>Field Service Actions (Recalls)</TD></TR><TR><TD>
    </TD><TD colSpan=2>Workshop Manuals</TD></TR><TR><TD>
    </TD><TD colSpan=2>And
    </TD></TR><TR><TD>
    </TD><TD colSpan=2>Wiring Diagrams</TD></TR><TR><TD>
    </TD><TD colSpan=2>
    </TD></TR><TR><TD>
    </TD><TD colSpan=2>
    </TD></TR><TR><TD>
    </TD><TD colSpan=2>
    </TD></TR></TBODY></TABLE>
    Sounds like this info is kinda generic, no? Since when was there any recalls done on Marauders? Did I miss something?
    PJR Guest
    It's pretty comprehensive. I got it on e-bay, I don't know if he has more. The link describes what's on it. Up until 2002 these were cd format. For 2003 Ford switched to dvd. I have cd's for other older models, F150, Taurus. They have come in handy numerous times.
    http://cgi.ebay.com/ebaymotors/ws/eB...tem=7984272665
    Connecticut
    So according to your first post, you're claiming that there's been a recall on Marauders, uh? That's funny, because I thought that I'd be notified in the mail of a recall IF that was the case. I know there was atleast one TSB, for the axles, but I've never heard of a recall.
    PJR Guest
    The dvd covers all Mercury and some Ford models. The headings are generic, they apply to all the models. There is not a recall for MM.
    Connecticut
    Okay PJR. That's what I thought, but I wasn't positive. Thanks for your reply, and for this info.
    Feb 2005
    Chicago 'Burbs
    This is one of many times I've read about this. I have not seen it at all.
    I've seen 9 others. Not one on the axles.
  1. Good info for the CAI buyer.
    By Tucker in forum JLT Performance
    Last Post: 03-20-2005, 12:03 PM
  2. Nitrous info and stuff
    By LimoMerc in forum Community Discussion
    Last Post: 02-02-2005, 11:40 PM
  3. Tire Pressure Info
    By Romo53 in forum Tires & Wheels
    Last Post: 12-07-2004, 05:24 AM
  4. How to determine car info?
    By Svashtar in forum Community Discussion
    Last Post: 07-13-2004, 03:57 AM
  5. Updated info on brakes coming tomorrow!
    By Todd TCE in forum TCE Performance
    Last Post: 10-12-2003, 05:33 PM
