Results 1 to 15 of 29
Thread: Roush Tensioner
    Feb 2005
    DC MD Area
    Roush Tensioner
    Anyone using the Roush Tensioner with a Eaton swap or Trilogy? If so does it fit behind the water overflow tank? Its a lot thicker so I just wanted to make sure before I order one. Doing a pulley, belt, and tensioner over haul on the car.
    2003 300A Black MM
    FRPP ALUMINATOR MOTOR 10:1
    STAINLESS WORKS LT HEADERS
    ADDCO FRONT & REAR SWAY BAR
    MONROE HD QUICK STRUTS FRONT
    QA1 ADJUSTABLE REAR SHOCKS
    The Dirty South
    I ran one for years on my old Trilogy. It fits against the degass reservoir with little room left.
    The reservoir will have to be unbolted to install the tensioner.
    Last I looked they were hard to find
    Feb 2005
    DC MD Area
    If we are talking about the same 8 rib tensioner then AmericanMuscle.com and Summit Racing has them for $133.99
    https://www.americanmuscle.com/roush...wDOA&gclsrc=ds
    https://www.summitracing.com/parts/r...YaAmH8EALw_wcB
    2003 300A Black MM
    I use this one, recommended from Jerry (lji372) it has double bearings. I too run a ported Trilogy with 2.8 upper/4lb lower..no issues thus far
    http://www.uprproducts.com/mustang-b...essory-03.html
    North Aurora, IL
    I’ve had the Roush tensioner for 6-7 years now. Works great and has not failed.
    Sent from the White House on the tax payers dime.
    Great quotes!!
    Eat poo poo and die heathen.
    Feb 2005
    DC MD Area
    Been looking at this too, best price I've seen. Do you have to swap over the pulley from the tensioner that came with the trilogy? Either way I'll buy a new one none the less...The purpose is preventative maintenance. Im using a 3.0 upper/4lb lower I use Gates belt K080525HD. Did you have to grind a lil material off your accessories tensioner to get it to not touch the 4lb lower? Mine had to be.....
    2003 300A Black MM
    Feb 2005
    DC MD Area
    Quote Originally Posted by guspech750 View Post
    Does it come with the correct pulley for the Trilogy and Eaton swap?
    2003 300A Black MM
    Quote Originally Posted by NATEHAWK View Post
    I bought a new 76mm pulley from upr at same time
    Definitely buy the UPR
    North Aurora, IL
    I can't answer that. I ordered it and just slapped it on. LOLzzz
    http://www.teamjdm.com/roush-tensioner-arm-pulley/
    Sent from my SM-T378V using Tapatalk
    Great quotes!!
    Feb 2005
    DC MD Area
    Thanks, any other sites you know that may have it in stock? UPR says not in stock at the time.
    2003 300A Black MM
    The Dirty South
    My old setup was:
    Trilogy w/3.0 upper pulley
    Stock Trilogy lower
    Roush tensioner
    Metco 90mm double bearing smooth idler
    I had a Roush tensioner fail on me and almost come apart
    Feb 2005
    DC MD Area
    I'll prefer the UPR Tensioner but if not available the Roush it is and the Metco 90mm double bearing pulley.
    2003 300A Black MM
    The Dirty South
    Been out of stock for more than a year now Nate. I looked high and low for the UPR for my new build and couldn't find any.
    Got tired of looking and bought the Thump RRR
  1. For Sale New Roush Spoiler
    By J.bo in forum Marauder-specific Parts for Sale
    Last Post: 08-07-2013, 02:02 PM
  2. Engineered by Roush?
    By Chad1987 in forum Community Discussion
    Last Post: 05-14-2013, 04:24 PM
  3. Roush Spoiler
    By STLR FN in forum Community Discussion
    Last Post: 01-08-2009, 11:46 AM
  4. Roush
    By Carolina Rauder in forum The Lounge
    Last Post: 07-16-2007, 04:15 AM
  5. Engineered by Roush ***DUW***
    By djv5150 in forum Community Discussion
    Last Post: 02-01-2006, 08:30 PM
