I did a search, found some decent information on what I MAY have broken, but some of my transmission's symptoms are a little unique. I am hoping someone can give me a good idea of what is wrong so I can resolve the issue as soon as possible.
Car: 03 A
Mileage: 65K
Trans serviced approximately 10K miles ago
Lidio tune
It happened taking off from a dead stop at W.O.T. The car accelerated good until it hit the 1-2 shift point, then it bounced off the revv limiter, no more drive gear. I pulled over, turned overdrive off and was able to drive it home. I checked the fluid, good, clean, full.
Current symptoms (overdrive on)
1) will not go into reverse
2) sometimes will go into first when fluttering the gas.
3) will shift from first to second (at an unusually high R.P.M)
4) If I do not keep accelerating in second it will fall in and out of gear
5) No third gear or overdrive
Overdrive off:
1) will shift 1-2, but at a very high R.P.M with a lot of hesitation
2) will shift into third fine
3) have reverse
I am sick to my stomach, guess I should not have been playing around so much. I appreciate any and all feedback, I am hoping it is something easy, but that may be a little too optimistic.
